Theres a Code or resistor value discrepancy for the GPIO0 for reset
when I remove R3 (1K) to disconnect the transistor for relay output the board boots and connects to the AP Correctly ,so its either the code or a resistor value
Considering adding a diode for output only on the R3 Trace so it doesnt see anything from the transistor side
Charles Lakins
