The challenge mostly involves prelithiation of the cathode, but can also be getting proper nitrogen functionalization of the cathodes graphene.
The rest including the solid gel electrolyte I have mostly figured out.
The breakdown
Anode: 80% pristine mechanically exfoliated graphene from high purity graphite. 5% silver plated copper flake. 15% PVDF PVA DE GO LiClO4 LiNO3 electrolyte/binder.
I will also be pitting this against 4 dollar a gram graphene bought from Celtig LLC.
Cathode: 80% Graphene oxide slightly reduced or atmospheric Plasma functionalized graphene. 5% nickel flake. 15% PVDF PVA DE GO LiClO4 LiNO3 electrolyte/binder
Seperator: GO, DE, LiClO4 LiNO3 in PVDF
Lithiation of the cathode, will be accomplished by ball milling with metallic lithium or half cell discharging of a lithium foil into the cathode.
All materials will be THF soluble and sprayable, paintable or printable.
Major issues are using an airbrush and clogging I may just dip coat the materials on foils to begin with. Other than that everything is pretty much straight forward.
This documentation describes Open Hardware and is licensed under the
CERN OHL v. 1.2.
You may redistribute and modify this documentation under the terms of the
CERN OHL v.1.2. (http://ohwr.org/cernohl). This documentation is distributed
WITHOUT ANY EXPRESS OR IMPLIED WARRANTY, INCLUDING OF
MERCHANTABILITY, SATISFACTORY QUALITY AND FITNESS FOR A
PARTICULAR PURPOSE. Please see the CERN OHL v.1.2 for applicable
conditions
MECHANICUS
MasterOfNull
Rory
