Many recent disaster situations have shown disrupted technical infrastructures were a real handicap for its victims. MEITH is an emergency portable computer, based on RPI3B/B+ as replacement for your desktop computer. It will last several days on its battery, while having access to a wide range of applications at your disposal when you really have a need for them. It will even continue to work in waterproof configuration.This provides MIGHT against the challenges you will have to face. Hence the acronym chosen for this project: MEIHT as it has the same pronunciation. More info you can find on www.meith.org.Hope to welcome you soon.Cheers,Jan & Paul
