Linear regression can be used for supervised machine learning. The graph below shows measuring points (input and output values) and its distance (residues) to a function computed by the method of least squares (line).
The model function with two linear parameters is given by
For the n input and output value pairs (x_1,y_1),...,(x_n,y_n) we are searching for the parameter a0 and a_1 of the best fitting line. The according residues r between the wanted line and the input and output value pairs are computed by:
Squaring and summation of the residues yields:
The square of a trinomial can be written as:
Hence:
We consider the sum function now as a function of the two variables a_0 and a_1 (the values of the learned data set are just considered as constants) and compute the partial derivative and its zero:
Solving the system of linear equations:
Substituting
as the arithmetic mean of the y-values and
we get:
Replacing a_0 in the equation
yields
Because
For a new input value
the new output value is given by
or
M. Bindhammer
