I have finally exported all the .prt files to .dwg files for laser cutting! You can see the DWGs in the file section, as well as a Adobe illustrator layout of all the parts for laser cutting. Home Depot sells 4'x4' 3/16 in plywood for $9. Not a bad deal.
