The second milestone is all about finalising the project and making sure we are realistic in the functional, financial and timely aspects. We're always working with the goal in mind: cheap computers for Malawi orphanage, how we get there is just a necessity and the procedure needs to be efficient.
Functional specifications
Things in bold have changed since the original functional specifications.
- External functions (hardware)
- Cheap
- About $50 per computer
- Maintainable
- Easily exchangeable parts in case something breaks if user maintainable
- Require only basic tools (fingers, screwdrivers...) to fix broken elements
- Light
- About 3Kg per computer
- Robust
- Do not break when subjected to light shocks, standard care for sensitive electronics applies
- Possibility to connect to the Internet
- Need internet connection for light data exchange (emails, documents)
- Connection does not have to be permanent
- Cheap
- Internal functions (software)
- Cheap
- Open-source and free software only
- Maintainable
- System easily updated with a graphical user interface (GUI)
- Easy installation of new software with a GUI
- No danger of data loss in case of power outage
- Backup system that saves a copy of sensitive data
- Robust against data corruption in case of power-loss
- Have office tools (text editor, spreadsheets)
- Google Docs, OpenOffice, LibreOffice...
- Cheap
Selected solution
- Power cable
- Keyboard
- Mouse
- Raspberry Pi 3
- Micro SD card (8GB)
- HDMI-DVI cable
- 5V power supply
- Micro-USB cable
- Audio cable
- Screen
Costs
One station will cost $62 and weigh about 8.5Kg. To this must be added the transport costs with add another $100, so total cost is $286 for three systems as the weight limit is 28Kg. With this system we achieve 25% of maximum fitness.
Planning
Gantt chart has not changed since last time. The second milestone log is late, however the project itself is well within limits and going strong.
