- GOALS:
- One way communication.
- Two way communication.
- Two way image transfer.
- Two way communication with a repeater for increased distance.
- Data encryption.
A crude schematic is shown below.
Based on Lifi we establish a communication protocol between two arduinos
i'm working on the same project from past few months.
This reminds me of a project I have done a while ago with a friend. Instead of LEDs we used laser diodes, this way you get a stronger signal from the photo diode. Since they are quite cheap, it's maybe worth a try for you.
please check : https://github.com/jpiat/arduino it does visible light communication on Arduino using two LED's (no photo-diode).
Now that is a really amazing project! In this project I plan on encoding an image and sending it to another computer.
Thank you very much for sharing your project! It helped me a lot to achieve mine: https://nerd-corner.com/sending-text-messages-with-visible-light-communication/
