figuring out the bits and pieces
A project log for 3d Battery Printer
I am upgrading my prusai3 to a massive build volume during which I will also be adding peristaltic pumps, for printing batteries
mechanicusMECHANICUS 04/13/2016 at 09:310 Comments
https://www.panucatt.com/Azteeg_X3_Pro_p/ax3pro.htm
I think the azteeg x3 pro will be the best option I will need to add a fourth extruder for placing an electric and ionic insulating material.
I picked up a bottle of CO2 and argon today from my jerb I might need to run straight argon in this system for any lithium or potassium hydroxide supercapacitors as they absorb CO2.
There is always that option or going with a delta morphology inside a composite reinforced cement tube. Then pulling a vacuum on the whole thing to reduce vapor pressure and reduce drying times.
Rich text editor
