1. adding ceramic antenna in order to reinforce the signal when external antenna is off.
2. fixed outside shape to have better identity and user friendly when adding breakout board.
3. adjust the screw hole so that the screw wont affect the nearby electronic.
4. fixed the silk print layout.
Joseph
