Hackaday.io Hackaday.io
Sign up Log in
Teensy audio pre-amp module
Small (hifi/stereo) pre-amp with teensy3.2 + audioshield
marcell-marosvolgyimarcell marosvolgyi
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
3k views
4 comments
2.1k followers
  • Description
  • Details
  • Files 0
  • Components 3
    • View all
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 4
View Gallery
3k
4
2.1k
21
Team (2)
  • marcell-marosvolgyimarcell marosvolgyi
  • lgmarosvolgyilg.marosvolgyi
Join this project's team
  • firmware
ongoing project
teensy audio dsp amplifier tonecontrol
Related lists
Alternative Audio Amplifiers
Interesting ways to amplify sound
Audio stuff
Audio-related projects
This project was created on 03/17/2016 and last updated 4 years ago.
Description
This is a small pre-amplifier with bass, treble, surround, compression and volume control. It is based on the teensy3.2 + audio shield. The user interface works with analog potmeters. I made a pcb which supports all the parts and wrote some software to control the whole setup. The software reads the analog pots and adjusts the parameters with software ramping to prevent 'clicks' while adjusting. More info will follow shortly ...
Components
  • 1 × teensy 3.2 https://www.pjrc.com/teensy/index.html
  • 1 × teensy audio shield https://www.pjrc.com/store/teensy3_audio.html
  • 6 × makerbeam http://www.makerbeam.com/
Project Logs
Collapse
  • Tiny hifi stereo tower
    marcell marosvolgyi • 03/22/2016 at 22:37 • 0 comments
    Tiny things with great capabilities. I though it would be nice to add an extra box with the adafruit max9744 breakout Now we have a tiny hifi stereo tower:
  • progress...
    marcell marosvolgyi • 03/19/2016 at 20:09 • 0 comments
    Experimenting with building an enclosure...
    Next version
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
Machinehum (Ryan Walker) wrote 07/06/2017 at 03:34 • point
Wow - really slick enclosure. Laser cut?
Alex Gorbatchev wrote 04/27/2017 at 16:31 • point
Could you post the schematic please?
lg.marosvolgyi wrote 03/19/2016 at 22:06 • point
Fenomenális amit létre hoztál, gratulálok.
lg.marosvolgyi wrote 03/19/2016 at 22:00 • point
Like the enclosure  very much. Sorry for the  skull.
Supplyframe DesignLab: 2022 Hackada…
A full desktop audio solution
Project Owner Contributor
DIY Computer Speaker+DAC Featuring Recycled Parts
justinas-petkauskasJustinas Petkauskas
The 2017 Hackaday Prize
J.A.N.I.S is a C# powered personal assistant. J.A.N.I.S stands for Just Another Non-human Intelligence Software.
J.A.N.I.S Your Personal Assistant
sagi-harushSagi Harush
This project is to document the teardown of the Positive Grid Spark 40 Amp, the internal components, and any cool mods!
Positive Grid - Spark 40 Teardown/Mods
michaelsheaffermichael_sheaffer
The goal is to add an infrared receiver to a low-end audio DAC and control the volume optical audio channel using TV remote.
Adding IR control to cheap audio DAC
robertstropsroberts.trops
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Teensy audio pre-amp module", please tell us the reason.
Send message
Remove Member
