CC3200 Development Board has a lot of useful hardware.
accelerometer and temperature and then expand to new
sensors and other hardware.
Thermopile Sensor in Chip-Scale Package.
BMA222 3-AXIS ACCELEROMETER DIGITAL SMD
The following function deals with HTTP
events. The source code can be downloaded from here. File name is ExositeCC3200CloudDemo-BETA-20140708.zip.
void SimpleLinkHttpServerCallback(SlHttpServerEvent_t *pSlHttpServerEvent,
SlHttpServerResponse_t *pSlHttpServerResponse){
Two events are of a particular interest at this point.
Temperature read:
ptr = pSlHttpServerResponse->ResponseData.token_value.data;
pSlHttpServerResponse->ResponseData.token_value.len = 0;
if(memcmp(pSlHttpServerEvent->EventData.httpTokenName.data,
GET_token_TEMP, strlen((const char *)GET_token_TEMP)) == 0)
float fCurrentTemp;
TMP006DrvGetTemp(&fCurrentTemp);
char cTemp = (char)fCurrentTemp;
short sTempLen = itoa(cTemp,(char*)ptr);
ptr[sTempLen++] = ' ';
ptr[sTempLen] = 'F';
pSlHttpServerResponse->ResponseData.token_value.len += sTempLen;
}Accelerometerread:
GET_token_ACC, strlen((const char *)GET_token_ACC)) == 0)
ReadAccSensor();
if(g_ucDryerRunning)
strcpy((char*)pSlHttpServerResponse->ResponseData.token_value.data,"Running");
pSlHttpServerResponse->ResponseData.token_value.len += strlen("Running");
else
strcpy((char*)pSlHttpServerResponse->ResponseData.token_value.data,"Stopped");
pSlHttpServerResponse->ResponseData.token_value.len += strlen("Stopped");
Both sensors share I2C bus for command and data communications.
Roman
