I finally received my Raspberry Pi Zero, just in time to get into the DIY challenge of building a smart drone with the Pi Zero and APM unde
Bill of Material (US$ - Transport & taxes excl.):
Raspberry Pi Zero 5.
MPU 9205 (SPI 9 dof IMU) 8.
MS 5611 (SPI Baro) 9.
PCA 9685 (16 channel PWM Servo Driver) 5.
3.3 v. regulator 1.
BEC 3 amps 3.
Breadboard, Resistors, Connectors, Misc. 7.
AutoPilot: 38.
HobbyKing Spec FPV250 V2 Quad Copter
ARF Combo Kit - Mini Sized FPV 60.
Total: 98.
*This is Banggood price; I had an ADAFRUIT –PWM on hand, and I really recommend going with ADAFRUIT, because of all the effort they put on making a great tutorial and drivers for this product. Note: Just like Erle , the USB WIFI, GPS and the Radio Control are excluded.
Building:
A) Hardest part: Get a RASPBERRY PI ZERO (Where is my Zero site)
B) Hardware - See BOM
C) Board Schematics : Erle pxfmini
D) Board Software: Erle pxfmini
E) LOAD LATEST Raspbian-Jessie
Disable serial Login (Allow GPS on serial Port)
Enable , I2C, SPI , Serial
Disable Console = Auto Log on a shell
F) LOAD RT-PREEMPT
http://www.frank-durr.de/?p=203
Load Test Result: TEST: T: 0 ( 1136) P:80 I:500 C: 100000 Min: 16 Act: 31 Avg: 32 Max: 157
G) MAKE ArduCopter
Special MINI-ZEE release:
1) The MPU 9205 is mounted on the Z-Axis, so we need to change :
CONFIG_HAL_BOARD_SUBTYPE == HAL_BOARD_SUBTYPE_LINUX_PXFMINI
, _default_rotation(ROTATION_YAW_270) = to ROTATION_NONE
2) The PCA9585 has no external clock, and the ESC are connected to ports 1-2-3-4, so we need to change:
static RCOutput_PCA9685 rcoutDriver(PCA9685_PRIMARY_ADDRESS, true, 3, RPI_GPIO_27); -to-
static RCOutput_PCA9685 rcoutDriver(PCA9685_PRIMARY_ADDRESS, false, 0, RPI_GPIO_27);
H) Fly the MINI-ZEE == Add these to /etc/rc.local
#wait till network is up and DHCP assigned address
while ! ifconfig | grep 192.168.2. >> /home/pi/bootlog; do
echo “no network, waiting…” >> /home/pi/bootlog
sleep 5
done
echo “Starting ArduCopter” >> /home/pi/bootlog
sudo /home/pi/ardupilot/ArduCopter/ArduCopter.elf -A udp:192.168.gcu-address:14550 -B /dev/ttyAMA0 > /home/pi/startup_log &
exit 0
I) FIRST FLY LOG:
Thanks to the damping platform, the vibration level is within specs. Video is available for anyone interested..;-)
Conclusion:
This project took about 20 hours to complete. As you can see, I really enjoyed doing some hardcore DIY to demonstrate that it is still possible to build your own flight controller from a Linux Based system. I do not recommend to try this as a first project, but if you are interested, get a BBBMINI, this is the best introduction to DIY and if you want to fly a Raspberry Pi Zero, it is much easier to buy a PXFMINI.
I was looking for tutorials of using RT PREEMPT and lucky to find this post. Normally I discard all websites with black background. I want to do MQTT on the linux side, not so much on the autopilot firmware. Do you recommend buying Erle's PXFMINI? You seem to recommend buying adafruit's breakout boards. But I think Erle's PXFMINI is much more compact.
Do you have the pfxmini firmware or do you know where i can download it since the website does not exist anymore. please
