Having cleaned the switches overnight, in the morning I started to work on the wiring. I used a two-sided tape to glue a Pro Micro to the base, added a USB cable (I had to file the plug a little to make it fit inside the keyboard), and started to add the wires and diodes.
I decided to use 3 rows and 8 columns, with the two large keys in the same row as the vowels on the bottom. This lets me return the row status as a single byte and makes the scanning quite fast.
For software, I used the same TMK keyboard firmware as in #Alpen Clack, with just two changes, one to the key map:
static const uint8_t PROGMEM keymaps[][MATRIX_ROWS][MATRIX_COLS] = {
{KC_W, KC_E, KC_R, KC_U, KC_I, KC_O, KC_P, KC_LBRC},
{KC_S, KC_D, KC_F, KC_J, KC_K, KC_L, KC_SCLN, KC_QUOT},
{KC_Q, KC_T, KC_C, KC_V, KC_N, KC_M, KC_NO, KC_NO},
};and one to the matrix functions:
/* Column pin configuration
* col: 8
* pin: PD0 PD1 PD2 PD3 PD4 PD7 PC6 PE6
static void init_cols(void) {
// Input with pull-up(DDR:0, PORT:1)
DDRD &= ~0b10011111;
PORTD |= 0b10011111;
DDRC &= ~0b01000000;
PORTC |= 0b01000000;
DDRE &= ~0b01000000;
PORTE |= 0b01000000;
static matrix_row_t read_cols(void) {
return (PIND&(1<<0) ? 0:(1<<0)) |
(PIND&(1<<1) ? 0:(1<<1)) |
(PIND&(1<<2) ? 0:(1<<2)) |
(PIND&(1<<3) ? 0:(1<<3)) |
(PIND&(1<<4) ? 0:(1<<4)) |
(PIND&(1<<7) ? 0:(1<<5)) |
(PINC&(1<<6) ? 0:(1<<6)) |
(PINE&(1<<6) ? 0:(1<<7));
/* Row pin configuration
* row: 3
* pin: PF7 PF6 PF5
static void unselect_rows(void) {
// Hi-Z(DDR:0, PORT:0) to unselect
DDRF &= ~0b11100000;
PORTF &= ~0b11100000;
static void select_row(uint8_t row) {
// Output low(DDR:1, PORT:0) to select
switch (row) {
case 0:
DDRF |= (1<<7);
PORTF &= ~(1<<7);
break;
case 1:
DDRF |= (1<<6);
PORTF &= ~(1<<6);
break;
case 2:
DDRF |= (1<<5);
PORTF &= ~(1<<5);
break;
}Unfortunately the Pro Micro doesn't break out any of its pin ports in whole, so I had to use multiple ports for the columns. I still have whole port B free, I might decide to add LEDs to the keys as a teaching help. For now let's keep things simple.
I don't have any CapsLock or NumLock keys, so the LEDs on the board are unused. I still placed it in such a place, that it is visible, just in case I might need them for something later.
Once I made all the connections and uploaded the firmware, I realized that 5 of the switches actually didn't survive the glue removal operation — they give no electrical connection. Fortunately I still had a bunch of switches left to replace them.
Now I'm going through the lessons at https://sites.google.com/site/ploverdoc/lesson-1-fingers-and-keys
deʃhipu
