I went out to laser cut the frame on Friday and put the machine together today to see how it looks and test it out. The machine is designed to have 1 inch thick material for the frame (either wood or HDPE) but I just wanted to make a quick frame mock up using 1/4 inch acrylic.
Check out our video of our dry run!
Next step is to put together the wiring and electronics box for the machine. We’re really close to milling some actual parts so make sure to stay tuned for more updates on that!
