The goal of this project is design and build an open-source and inexpensive photometer that could aid in the testing of water for contamination. The design will use off-the-shelf components and a micro-computer (i.e. RPi or Arduino) to control the test. The goal would be to quickly read a test-strip and communicate the results back to the user via a web interface.
Dear Matthew,
I had a similar idea, initially being more interested in pH measurement, and worked out a bit different solution using RGBW and/or luminometric sensors on Adafruit I2C breakouts.
The construct is working well, but in the last month I had to focus on other things.
You can find the project description here: http://www.instructables.com/id/An-Inexpensive-Photometer-and-Colorimeter/ . Let me know if I may provide any help for your project.
What type of indicators have you be planning to use for Pb quantification?
I recently had bought a set of testing kits used for aquariums that includes heavy metal detection reagents, but have not performed any measurements by now.
Kind regards
Holger
