Progress on the assembly front! The frame is back together and the wiring is almost complete. I have had to rewire a large portion to allow for the Gshield and Printrboard to used the same motor inputs. They are both tied into the same terminal block now and all I have to do is turn on either one so they will have motor access! The machine is back together and moving, I will most some of the first cut videos soon.
Alex Anderson
