Before going forward and designing the gasoline combustion engine module, I wanted to take a moment and think through the energy requirements and use that to drive the sizing of the engine.
My working theory is that to maintain a cruising speed of 100 KMPH (roughly 60 MPH) on a flat grade would require something on the order of 30 KW with an "average" vehicle (drag coefficient, weight, rolling resistance). If that is true, then a 40 HP engine (roughly 30 KW) would be enough to power the vehicle. Now note this is to maintain a cruising speed. Acceleration is a separate case and needs to be handled by studying the expected duration and magnitude of acceleration and to size the engine and capacitor banks accordingly. That is a much more complex issue and will be looked into a future time.
For now, I want to present a back of the envelope approach as to how I am viewing the issue and to see if my theory that a 40 HP engine will be sufficient to cruise at highway speeds.
Weight of the vehicle - 1850 kg
http://www.nytimes.com/2004/05/05/business/average-us-car-is-tipping-scales-at-4000-pounds.html?_r=0
Drag coefficient of the vehicle - 0.35
https://en.wikipedia.org/wiki/Automobile_drag_coefficient
Rolling Resistance of tires - 0.03
http://www.engineeringtoolbox.com/rolling-friction-resistance-d_1303.html
Distance traveled per second is 27.78 meters/second (100 Kilometers per hour)
Power consumed to overcome rolling resistance = rolling resistance * normal force * distance traveled per second
0.03*1823.9 kg *9.8 m/s^2 *27.78 m/s = 14896.37 J/s
Power consumed by drag = 0.5*density of air (assuming 25 C)*velocity of the object (assuming still air)*area exposed to oncoming air*drag coefficient * distance traveled per second
0.5*1.1839 kg/m^3 * (27.78 m/s)^2* 3 m^2 * 0.35 * 27.78 m/s = 17766.82 J/s
14896.37 + 17766.82
Overall power consumption to maintain 100 KMPH = 32663.19 Watts or roughly 32.6 KW
James Nee
