Hackaday.io Hackaday.io
Sign up Log in
Smart Mail Box
“Smart Mail Box” system detects the new post mail arrivals along with sender specific details and notifies the user via Email (Ex Gmail)
ashokAshok
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
5 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
  • The 2016 Hackaday Prize
View Gallery
257
0
5
3
Team (1)
  • ashokAshok
Join this project's team
MISC
ongoing project
2016HackadayPrize Smart MAIL iot
This project is submitted for
  • Get Started: Design Your Concept
This project was created on 03/23/2016 and last updated 6 years ago.
Description
Even when the tech bubble is at its peak, we have still not forgotten the classic old fashioned handwritten notes. An email can never replace a handwritten note. The speed of an email follow-up is great but it can often get buried in a busy person’s inbox (or even get lost in the “junk mail” folder if you’re sending it from an unfamiliar address). In today’s era, when sadly we’re getting fewer and fewer letters in the mail, a handwritten thank you note, well-crafted on good stationery, will make a candidate stand out from others who chose not to take that extra, personal step.
Its built in with LPC 43S67 MCU cloud kit, Sensors, and Stepper motor. The board also have the Wi-Fi module (Zentri) which helps to send mail in smtp mode. The sensors helps the controller to detect the new mail arrivals and mail box open/close controls. The sender information are received through the NFC reader from the Postman using handheld device/smart phone. New m
Details
Log In/Sign up to comment
Sign up with Github
OR
This topic shows you how to setup Microsoft Azure IoT environment on LattePanda!
Project Owner Contributor
LattePanda with Microsoft Azure - Getting Started
caveduCAVEDU
The worlds first military grade open source robot!
R.O.B.
rudyaramayoRudyAramayo
Mini-ROVER v2.0
garagehackerGarageHacker
A smart sensor Node to trigger an action on a smartphone each time a physical change is detected (temperature, displacement, click...)
Triggy - Sensor Node for Life Automation
vinchVinch
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Smart Mail Box", please tell us the reason.
Send message
Remove Member
