Although natively working with 16-bit words (14-bit pairs of instructions or data), CPU7 is also supposed to handle "raw" unformatted data in 8-bit, 16-bit, or 32-bit format. As an example that could be a hardware register, video memory, or anything which is not part of CPU7.
As a small coding exercise to test the flavour of the CPU7 assembler, here is the well known "bubble sort" of an area of unformatted bytes.
'! usage: addr len bubblesort8
:bubblesort8
dup 1 > if `! check if the array is more than one element
enter
1 over + `! calculate end=addr+len; stack: beg, end
1 swap dup `! stack: end, beg, addr
repeat
dup rd8 `! stack: end, beg, addr, [addr]
1 over ++ rd8 `! stack: end, beg, addr, [addr], [addr+1]
< if `! stack: end, beg, addr
++ `! addr=addr+1
else
2 over wr8 `! stack: end, beg, addr, [addr]
1 over ++ wr8 `! stack: end, beg, addr
drop dup `! addr=beg; stack: end, beg, addr
endif
dup 3 over < until
leave `! clean up the data stack
endif
drop drop `! remove the input parameters from the data stack
