aPCmeter
Arduino Based Illuminated Vintage CPU and RAM Gauges
aPCmeter is an open source, Arduino Nano based, illuminated vintage looking CPU and RAM gauges box project. See https://github.com/alperyazar/aPCmeter for further details.
View all 2 project logs
View all instructions
Alper wrote 03/26/2016 at 15:38 • point
Thank you. As a note, you can find similar projects too. The idea doesn't belong to me. ;)
hayden wrote 03/29/2016 at 20:19 • point
Well i did and that helped too, but thanks for posting as i didnt know about it. i made one yesterday with 3 meters, no leds yet. what software are u using on the pc to send to the arduino  ? i spent a while trying a few options, and ended up finding a fork of Open Hardware Monitor with serial support, which is great as it has many stats to choose from. https://github.com/cody82/open-hardware-monitor
hayden wrote 03/30/2016 at 00:03 • point
Alper wrote 05/07/2016 at 19:13 • point
I checked your project, it looks cool. I did a little modification on the software found on http://www.lungstruck.com/projects/pc-meter/ (you reffered to this page too) basically for changed serial protocol. I will look at your forked code.
DJ-TrainR3k wrote 03/13/2017 at 03:40 • point
Hello Alper, If it's not too much of a hassle, I'd like to see the serial protocol modified version of the lungstruck.com PC meter software as I am trying to work out a port of the code for use on linux systems.
Alper wrote 03/18/2017 at 07:17 • point
Hi,
Do you want to use aPCmeter with the modified software or just want to see the modified version without using it aPCmeter? Later, I didn't use the modified software this was only for initial tests. Although I didn't publish it yet, I wrote a Python script from scratch to communicate with aPCmeter properly. If you wish, I can send the Python script run on a computer to use aPCmeter. The my modified version of the lungstruck.com may not help you much depending on your needs because as far as I remember, I changed couple of lines.
hayden wrote 03/26/2016 at 12:57 • point
cool idea !
