I just discovered this chip : the STATEK PXO-1000 integrated quartz oscillator with integrated predividers.
http://pdf.datasheetarchive.com/datasheetsmain/Datasheets-8/DSA-154595.pdf
Yes it's pretty practical to hack a tiny frequency generator with a minimum part count. I ordered a few of these antiques that don't seem to grow old.
Of course "I could do this with a PIC" but the total absence of programming is worth it :-)
In the same vein, after a hint from @K.C. Lee, I got myself a bunch of PLLs.
Actually it's called a "zero-delay clock buffer" with 8 outputs but the CYPRESS CY2308SC-4 also works as a frequency doubler that can output between 10MHz and 133MHz.
By playing with the feedback signal, not only I can smooth the signal (reducing the jitter) but also bring the frequency much higher. I expect my Rb source to output 20MHz, which will be halved by the ALU, but I can reach up to 120MHz :-)
Another discovery from http://www.jmargolin.com/vgens/vgens.htm :
"The BRM used by Atari was the 7497. The 7497 is a 6-bit BRM. With a digital input of 63, it will produce 63 output pulses for every 64 input clocks. With a digital input of 1 it will produce one output pulse every 64 input clocks. Two 7497s were chained together to produce a 12-bit BRM. The data sheet for the 7497 is available here (PDF 282KB)."
Of course, all of this would run faster, better and take less power if I just used a A3P250.
Yann Guidon / YGDES
wow, never seen a chip looking like that.
Neither did I.
Instant buy (after consulting online resources).
The DS32KHZ and DS3231 seem to be derived from this hybrid approach, maybe STATEK got bought by Dallas ?
You can also add an external divider on the feedback path to do a higher multiplier ratio in a single stage. You can use a loadable counter to implement divide by n.
http://www.cypress.com/file/38066/download figure 13
There are limitations on cascading multiple PLL as it will increase jitters at each stage.
http://www.eetimes.com/document.asp?doc_id=1225577
I don't think the CY2308SC has an externally accessible feedback path... Did I overlook something in the datasheet ?
16 FBK PLL feedback input
The soic-8 CY2305 has an internal feedback.
Daaaaaamn again, you're right... I'll have to examine this. Soon. But now I have to find very high speed predividers...
Reading further, I see that the CY2308's REF input is 5V tolerant.
Awesome!
