In this revision of the code editor, I added line numbers and syntax highlighting (sort of). The line numbers consist of text on a canvas that is refreshed every time a key is pressed, a left click occurs, or a click and drag occurs. Syntax highlighting utilizes the Text.search() function supported by Tkinter. I also decided to use two files for this project to keep the main file (slightly) less cluttered. Code (with very few comments) below:
Main file (assemblerv2.py):
from Tkinter import *
from tkFileDialog import *
from tkFont import *
import os.path
import sys
import re
from assemblerlib import *
basefilename = "Untitled"
filename = ""
fileexists = False
canvaswidthdefault = 20
canvaswidth = canvaswidthdefault
currentlength = 1
mnemonicstring = "sll|add|sub|nand|nor|bez|bnez|bgez|blez|bgz|blz|lw|sw"
registerstring = "r0|r1|r2|r3|r4|r5|r6|r7"
def openFile():
global filename
global basefilename
openfilename = askopenfilename()
if openfilename is not None:
filename = openfilename
basefilename = os.path.basename(filename)
asmfile = open(filename, "r")
asmfile.seek(0)
asmdata = asmfile.read()
textArea.delete("1.0", "end - 1c")
textArea.insert("1.0", asmdata)
asmfile.close()
filemenu.entryconfig(filemenu.index("Save"), state = NORMAL)
frame.title("muCPU Assembler [" + basefilename + "]")
frame.focus()
initonOpen()
def saveFile():
global filename
asmdata = textArea.get("1.0", "end - 1c")
asmfile = open(filename, "w")
asmfile.seek(0)
asmfile.truncate()
asmfile.write(asmdata)
asmfile.close()
def saveFileAs():
global filename
global fileexists
global basefilename
saveasfilename = asksaveasfilename()
if saveasfilename is not None:
filename = saveasfilename
fileexists = True
asmfile.seek(0)
asmfile.truncate()
asmfile.close()
frame.focus()
def exitApp():
frame.destroy()
sys.exit()
def compileASM():
global filename
cpu_out = ""
asm_in = textArea.get("1.0", END)
asmlines = re.split("\n", asm_in)
for i in range (len(asmlines)):
if (asmlines[i] != ""):
cpu_out += str(i) + " => x\"" + decode(asmlines[i]) + "\",\n"
name, ext = os.path.splitext(filename)
hexfilename = name + ".hex"
hexfile = open(hexfilename, "w")
hexfile.seek(0)
hexfile.truncate()
hexfile.write(cpu_out)
hexfile.close()
def updateLinesEvent(event):
drawLinenums()
def updateHighlightEvent(event):
highlightSyntax((re.split("\.", textArea.index(INSERT))[0] + ".0"), INSERT)
def initonOpen():
highlightSyntax("1.0", END)
drawLinenums()
def drawLinenums():
global canvaswidth
global canvaswidthdefault
linenumbers.delete("all")
i = textArea.index("@0,0")
while True:
dline = textArea.dlineinfo(i)
if dline is None: break
y = dline[1]
linenum = str(i).split(".")[0]
linenumbers.create_text(canvaswidth, y, anchor=NE,text=linenum)
i = textArea.index("%s+1line" % i)
linenumbers.config(width = canvaswidth)
def highlightSyntax(start, end):
global mnemonicstring
global registerstring
mnemoniclen = StringVar()
registerlen = StringVar()
numberlen = StringVar()
pos = start
while True:
pos = textArea.search(mnemonicstring, pos, end, regexp = True, count = mnemoniclen)
#print pos
if not pos: break
textArea.tag_add("mnemonic", pos, pos + " + " + str(mnemoniclen.get()) + "c")
posarry = re.split("\.", pos)
posarry[1] = str(int(posarry[1]) + 1)
pos = posarry[0] + "." + posarry[1] + ("0" * (len(posarry[1]) - 2))
pos = start
while True:
pos = textArea.search("-?\\d", pos, end, regexp = True, count = numberlen)
#print pos
if not pos: break
textArea.tag_add("number", pos, pos + " + " + str(numberlen.get()) + "c")
pos = start
while True:
pos = textArea.search(registerstring, pos, end, regexp = True, count = registerlen)
#print pos
if not pos: break
textArea.tag_add("register", pos, pos + " + " + str(registerlen.get()) + "c")
Tk().withdraw()
frame = Toplevel(bg="#D8D8D8")
frame.bind("<Key>", updateLinesEvent)
frame.bind("<Button-1>", updateLinesEvent)
frame.bind("<B1-Motion>", updateLinesEvent)
frame.bind("<ButtonRelease-1>", updateLinesEvent)
frame.bind("<Key>", updateHighlightEvent)
scrollbar = Scrollbar(frame)
scrollbar.pack(side = RIGHT, fill = Y)
textArea = Text(frame, height = 30, width = 100, padx = 3, pady = 3, yscrollcommand = scrollbar.set)
textArea.pack(side=RIGHT)
scrollbar.config(command=textArea.yview)
mnemonicfont = Font(frame, family = "Courier", size = 10, weight = "bold")
textArea.tag_config("mnemonic", foreground = "blue", font = mnemonicfont)
numberfont = Font(frame, family = "Courier", size = 10)
textArea.tag_config("number", foreground = "#585858", font = numberfont)
registerfont = Font(frame, family = "Courier", size = 10)#, slant = "italic")
textArea.tag_config("register", foreground = "red", font = registerfont)
linenumbers = Canvas(frame, width = canvaswidthdefault, height = 487, bg = "#D8D8D8", highlightbackground = "#D8D8D8")
linenumbers.pack()
menubar = Menu(frame)
filemenu = Menu(menubar, tearoff=0)
filemenu.add_command(label="Open", command=openFile)
filemenu.add_command(label="Save", command=saveFile, state = DISABLED)
filemenu.add_command(label="Save as...", command=saveFileAs)
filemenu.add_command(label="Exit", command=exitApp)
menubar.add_cascade(label="File", menu=filemenu)
runmenu = Menu(menubar, tearoff=0)
runmenu.add_command(label="Compile", command=compileASM)
menubar.add_cascade(label="Run", menu=runmenu)
frame.config(menu=menubar)
initonOpen()
frame.resizable(0,0)
frame.mainloop()
#Current code
lw r4, 176(r0)
lw r3, 177(r0)
sub r2, r4, r1
bez r2, 8
sw r1, 252(r0)
bez r0, -8
add r1, r1, r3
sll r0, r0, r0
bez r0, -2
Library file (assemblerlib.py):
import re
def asmtoint(asm):
asm_split = re.split(" |, |\(|\)", asm)
args = []
for i in range (len(asm_split)):
if (asm_split[i] != ""):
args.append(asm_split[i])
#print args
opcode = 0
func = 0
rd = 0
rs = 0
rt = 0
imm = 0
if (args[0] == "sll"):
if (len(args) != 4):
return 0,0,0,0,0,0
opcode = 0
func = 0
rd = int(args[1][1:])
rs = int(args[2][1:])
rt = int(args[3][1:])
elif (args[0] == "add"):
return 0,0,0,0,0,0
opcode = 0
func = 1
elif (args[0] == "sub"):
return 0,0,0,0,0,0
opcode = 0
func = 2
elif (args[0] == "nand"):
return 0,0,0,0,0,0
opcode = 0
func = 3
elif (args[0] == "nor"):
return 0,0,0,0,0,0
opcode = 0
func = 4
elif (args[0] == "bez"):
if (len(args) != 3):
return 0,0,0,0,0,0
opcode = 1
rt = 0
rs = int(args[1][1:])
imm = int(args[2])
elif (args[0] == "bnez"):
return 0,0,0,0,0,0
opcode = 1
rt = 1
imm = int(args[2])
elif (args[0] == "bgez"):
return 0,0,0,0,0,0
opcode = 1
rt = 2
imm = int(args[2])
elif (args[0] == "blez"):
return 0,0,0,0,0,0
opcode = 1
rt = 3
imm = int(args[2])
elif (args[0] == "bgz"):
return 0,0,0,0,0,0
opcode = 1
rt = 4
imm = int(args[2])
elif (args[0] == "blz"):
return 0
opcode = 1
rt = 5
imm = int(args[2])
elif (args[0] == "lw"):
if (args[-1] == ''):
args = args[0:-1]
if (len(args) != 3 and len(args) != 4):
return 0,0,0,0,0,0
opcode = 2
rt = int(args[1][1:])
if (len(args) == 3):
imm = 0
else:
imm = int(args[2])
rs = int(args[3][1:])
elif (args[0] == "sw"):
args = args[0:-1]
return 0,0,0,0,0,0
opcode = 3
imm = 0
else:
imm = int(args[2])
else:
return 0,0,0,0,0,0
return opcode, rs, rt, rd, func, imm
def inttohex(opcode, rs, rt, rd, func, imm):
if (opcode == 0):
opstr = format(opcode, '02b')
rsstr = format(rs, '03b')
rtstr = format(rt, '03b')
rdstr = format(rd, '03b')
fnstr = format(func, '05b')
#print opstr, rsstr, rtstr, rdstr, fnstr
instruction = opstr + rsstr + rtstr + rdstr + fnstr
else :
if (imm < 0):
imm2s = ((-imm) ^ 255) + 1
immstr = format(imm2s, '08b')
else :
immstr = format(imm, '08b')
#print opstr, rtstr, rsstr, immstr
instruction = opstr + rsstr + rtstr + immstr
return format(int(instruction, 2), '04x')
def decode(asm):
opcode, rs, rt, rd, func, imm = asmtoint(asm)
instruction = inttohex(opcode, rs, rt, rd, func, imm)
return instruction
