Computer display update:
- Got a Crown 5" Color TV set from E-bay, dismantled it and installed in some old military rocket programming device made in West Germany back in the 80s;
- I managed to acquire some needles (pointers) for the analog gauges;
- Using GIMP Toolkit (Photoshop for Unix) I painted the analog dials;
- Started to install the needles on the indicators. The original dash board has 6 analog gauges: RPM, speed, battery, gas level, oil pressure and engine temperature. Added two more gauges for radiation level and battery charge (negative for drain, positive for charge).
Pictures are posted in the "files" section.
______________________________________
kernel panic: improbability coefficient below zero
Raspberry PI configuration in progress - installed FreeBSD Unix, installed a graphical user interface. Pictures will be uploaded as soon as I return from work.
