Software started
A project log for Home Cloud
A Raspberry Pi based distributed file and service platform.
dannyDanny • 06/28/2014 at 10:07•0 Comments
So I've started working on the software to be used to hang all this stuff together.
Afterall the hardware design is nice to use for this project, and indeed with practically ANY linux distribution can be a regular standalone webserver or FTP or database, mail, dns or any other server.
But the point of this project is to provide a decent device, with a real purpose.
The small unobtrusive box with very little on show aspect of this project is a nice way where people can get this box into their homes, nestled under their broadband routers etc, but for people to want the box it needs to have a purpose, that purpose is provided by the software.
The task of trying to build a free and open "cloud" solution for sharing files -think of it as a CDN, is not trivial. trying to make it as robust and secure as possible is also pretty daunting!
The fact that I'm not even 100% through with the planning part is a sure sign that I'm not ready to start writing code yet, however, I need some break from process flow charts.
I have been sketching out some process diagrams, (most of which can be simplified to the simple mantra of "connect, Authenticate, Share") so that's what I'm starting to write as code at the moment.
I had toyed with the idea of making things "simple" from the start.
so connectting to a gateway that can't be changed, on a port that can't be changed, but after a short while things need to be user configurable, so it only makes sense to start off with the whole program being configurable!
The perhaps single biggest limitation that I'm coming up against right now is that I am not a software developer by trade, this means that the way in which I write and present code may be different from what others expect.
Since this is an open source project. I've decided to try to write everythign in as modular fashion as possible. and everything being as generic as possible
In practice what this means is that I'm farming everything out as functions. The good thing about having got process flow charts down on paper is that I know that "connect" is a function, and that "Authenticate" is a process made of many functions. so it's reasonably easy to know what functions I need, -and what those functions need to accept and return...
In this way, if a person wants to add or remove funcionality, or change the way in which a connecttion happens they need only change that specific part, -and without thousands of lines of source code to worry about the software should be more inviting to change.
Code blocks won't be coppied and pasted. functions will be re-used in a place where copy and paste is tempting. -what I mean is that the code to connect to the Gateway server/entry point to the network, should be no different to the code used to connect to other peers.
The way that a hash of a file is made should use the same code at the code used to hash a file part or password. in practice this means that a vulnerability found in the hashing code would affect all parts of the program, but it also means that when a problem is fixed it is fixed everywhere, there isn't lingering bits of code hidden in a place where they were copied to.
