Important module of the motor is the temperature sensor. I added the sensor so that I can control the temperature of the motor. The sensor measures the temperature and if it's above [X] degrees celsius I need to stop the motor to prevent it from overheating. If the motor overheats it can be damaged. So the motor will stop in the same moment when overheating is detected.
See in next video how all that looks.
