This PCB prototype I used it to test how the motor will work. In this PCB I have attached sockets for Wireless, Arduino, FTDI and three male pins for power, ESC Controller and Temperature sensor. With the wireless module I'm connecting the front part of Pedaless, I mean the Dashboard. Temperature sensor is attached to the motor and is reading the temperature from there. If the temperature is too high
I'll stop the motor from running in order to prevent it from burning.
