The heart of a Perceptoscope is made of glass.
More specifically an assembly of prisms and lenses. This week I took the opportunity to experiment with some new approaches to building the crystal that sits center.
Beamsplitter cubes were always an especially difficult optical component to source at the specifications I needed. Funny enough if I glue them together, right angle prisms are fairly easy to get.
My original assembly was never really designed with manufacture in mind. I needed to think of something easily reproducible for the supply chains I could establish.
I had an idea for a new type of shell that would close around the optics to hold their alignment, so I mocked up a prototype monocle with some components I had laying around.
This should work fairly well as an approach to the final assembly. I can really optimize the optical properties quickly for a set of given components too.
