New Server!
A project log for Boxes.py
Cut out boxes and other stuff with a laser cutter
florian-festiFlorian Festi • 05/13/2024 at 20:25•0 Comments
As people surely have noticed the web instance was pretty slow at times. The issue was not really too much load but some weird latency or time out problem. As my hackerspace has setup a new server I asked if they would host Boxes.py. So now a new instance is available at https://boxes.hackerspace-bamberg.de. I added a redirect to the old location so you end up there no matter what. For now this is still in testing. Please report any issues you have here or on the GitHub project. If everything works out fine I will change all the links to the new instance.
Update: Looks like everything is working fine. I switched over the URL in all places I could think of. So the web instance is now officially move to its new home. Please enjoy the much quicker response times!
