I made a small tweak for a colleague, giving the nosepokes slide connectors so they can be physically connected in a line. This print requires a high resolution printer, such as a resin-based printer to make use of the slide connectors. (I tried it on a PLA printer not nearly enough resolution for the slides to work well).
This is a modular design that allows for any number of nosepokes to be connected in a row like this:
