Here are some screenshots of what the signals at different test points look like. This can be helpful for finding the source of a problem.
IR2104 Pin 2:
IR2104 Pin 5:
IR2104 Pin 6:
IR2104 Pin 7:
IR2104 Pin 8:
Between C3 and R2:
A project log for Arduino MPPT Solar Charge Controller
The charge controller consists of a buck converter that is controlled by an Arduino via a half-bridge driver.
IR2104 Pin 2:
IR2104 Pin 5:
IR2104 Pin 6:
IR2104 Pin 7:
IR2104 Pin 8:
Between C3 and R2:
