I damaged another Arduino Pro Mini, due to overloading the internal voltage regulator. Time to try something different. (The Arduino still works, as seen in the picture, except for the RAW input). Let's supply the Arduino with 5 Volts on the VCC pin, rather than around 8 Volts on the RAW input. This will also free the Arduino Pro Mini from having to supply the power for the INA3221 board and the LCD.
As a first approach I tried a 7805 linear voltage regulator which works, but is very inefficient.
So I decided to use one of the buck converters which I had tested in the past. The advantage is that I can use the 5 Volts from the same buck converter for the Arduino as well as the load which is a Banana Pi. So only one buck converter in the whole system.
Efficiency:
DROK Analog with USB
Riorand
Tobias
