The first photo above shows how the PWM Led is used in a macro. The Attack parameter states how much time to take to ramp the Led up to full brighteness. The Sustain parameter is how long to maintain full brightness. Release is how long to return to ramp down to an off state. Interval is the time between pulsations and Max Brightness is how bright you want your Led.
Uses for pulsation can include fun things like adding pulsating beacons on a model radio tower for instance.
tomtibbetts
