Big change#1: Converted the code to use non-blocking time. Previously I had used a series of for loops to stall the methods (i guess these are methods, I'm assuming this is coded in C?). These methods worked on the emulator, but not on the badge, as they relied on actual program execution speed, not the clock.
Big Change#2: Modified existing character generation code to use buffer[x] writing instead of for loops and hard coded pixels that I had previously implemented. This saved me ~3.4Kb off of the bh-badge-animate.c file. This leads us to Big change No.3!
Big Change#3: Because of the change in No.2, and No.1 above, I could now easily implement scrolling text for my "Game Over" sequence. After the ball moves off of the screen, a message scrolls from 0 to 15 that states "GAME OVER!", and then player 1, followed by player 2 scores are shown on the badge. Previously, due to my timing and delay's consisting of for loops, I was unable to reliably time the scrolling of text, so I omitted that feature, and instead displayed 3 to 4 characters at a time on the display, which was not graphically appealing.
In all, I only added one method to my program to implement these changes, and replaced poorly designed code to achieve the rest. Here's some documentation;
uint8_t ballX = 4; //X position of the ball
uint8_t ballY = 9; //y position of the ball
int p1 = 1; // player 1 (nearest 0,0) paddle position
int p2= 1; //player 2 (opposite 0,0) paddle position
uint8_t angle = 0; //angle of the ball. When looking at emulator, -1 moves the ball left,decreasing along the axis, while 1 moves right, increasing along the axis. 0 has no change in axis position. values: -1,0,1
uint8_t direction = -1; //direction that the ball is heading, -1 decreases along the axis, +1 increases along the axis. values: 1, -1
int c; // unused variable
uint8_t d; //unused variable
int i; //doubly declared incremental variable
int bumpers = 0; //unused variable. would have enabled a hidden game mode that would not allow the ball to go off of the screen, and made the game play like air hockey.
int p1Score = 0; //player 1 score
int p2Score =0; //player2 score
int speed = 1000; //unused speed variable. written in to allow game play to increase speed with more successive ball hits. did not work as planned, caused the ball to lose control.
void eraseBall(void); //method that deletes the pixel located at ballX, ballY
void moveLeft(void); //method to move p1 paddle left
void moveRight(void); //method to move p2 paddle right
void moveUp(void); //method to move p1 paddle right
void moveDown(void); //method to move p2 paddle left
void drawPaddle(uint8_t x); //method to draw paddle. input values: 0, 1. Accepts an integer and draws the paddle on either end of the screen, 1 for p1, 0 for p2
void erasePaddle(uint8_t x); //method to erase paddle. input values: 0,1. Accepts an integer and erases the paddle on either end of the screen, 1 for p1, 0 for p2
void ballMover(void); // method that increments the ball in the correct x and y directions, and then redraws ball.
void gameOver(void); //method that draws the game over message and displays p1 and p2 scores on the screen
void drawG(uint8_t x); //method to draw the letter g at relative to y axis location. accepts integer 0-15.
void drawA(uint8_t x); //method to draw the letter a at relative to y axis location. accepts integer 0-15.
void drawM(uint8_t x);//method to draw the letter m at relative to y axis location. accepts integer 0-15.
void drawE(uint8_t x);//method to draw the letter e at relative to y axis location. accepts integer 0-15.
void drawO(uint8_t x);//method to draw the letter o at relative to y axis location. accepts integer 0-15.
void drawV(uint8_t x); //method to draw the letter v at relative to y axis location. accepts integer 0-15.
void drawR(uint8_t x);//method to draw the letter r at relative to y axis location. accepts integer 0-15.
void drawP(uint8_t x);//method to draw the letter p at relative to y axis location. accepts integer 0-15.
void drawEX(uint8_t x); //method to draw the ! at relative to y axis location. accepts integer 0-15.
void drawOne(uint8_t x);//method to draw the number 1 at relative to y axis location. accepts integer 0-15.
void drawTwo(uint8_t x); //method to draw the number 2 at relative to y axis location. accepts integer 0-15.
void drawThree(uint8_t x); //method to draw the number 3 at relative to y axis location. accepts integer 0-15.
void drawFour(uint8_t x);//method to draw the number 4 at relative to y axis location. accepts integer 0-15.
void drawFive(uint8_t x);//method to draw the number 5 at relative to y axis location. accepts integer 0-15.
void drawSix(uint8_t x);//method to draw the number 6 at relative to y axis location. accepts integer 0-15.
void drawSeven(uint8_t x);//method to draw the number 7 at relative to y axis location. accepts integer 0-15.
void drawEight(uint8_t x);//method to draw the number 8 at relative to y axis location. accepts integer 0-15.
void drawNine(uint8_t x); //method to draw the number 9 at relative to y axis location. accepts integer 0-15.
void drawZero(uint8_t x); //method to draw the number 0 at relative to y axis location. accepts integer 0-15.
void drawColon(uint8_t x);//method to draw the : at relative to y axis location. accepts integer 0-15.
void wipePaddle(void); //method that clears lines 1 and 14 to remove excess balls caused by the scoring conditionals
void animateBadge(void); //main method that accepts keystrokes and drives the program/
