The RAD series neck attaches to the head with 3 screws, but since you have to remove it from the torso to undo them I figured it would be more secure to just print a new neck that could be glued to the head. I'm still debating whether to limit the rotation or add a servo mount.
![](https://cdn.hackaday.io/images/3377301462000298629.jpg)
