Just got this book from ebay:
and there (surprise-surprise!) schematics of the trigger on P-N-P germanium transistors that could be used in counters or shift-registers :)
2N123 is similar to Russian МП42Б (MP42B), 1N192 is similar to Russian Д219А (D219A), HD6001 and HD2085 didn't have direct analog in USSR, but I can try to apply the idea to my current T-trigger circuit...
Are you sure you need all those diodes and parts ? A simple divider-by-two flip-flop can use less parts...
(ok the voice is as old as your book ;-) )
Found 3rd edition (1958) online:
http://chiclassiccomp.org/docs/content/computing/GE/ECG-315_TransistorManualThirdEdition.pdf
It has more information about transistor logic!
awesome !
What is the date of this book ? :-)
Unfortunately I can't find it anywhere
On one table inside it's saying
JULY 1
1 9 5 7
