End to End Solution
A project log for ViaConnect Circuit Board Test Tool
Have a via on a circuit board that needs to be tested, but can’t or don’t have a connector? just use the ViaConnect.
david-spindenDavid Spinden 05/30/2016 at 02:380 Comments
The ViaConnect works for standard 0.1"/2.54mm header vias (about 35mils wide), but what about the other end? To name a few, It can be:
Here is a picture showing a Dupont header in the back as an example:
Rich text editor
