After a summer "break" of staining a deck, hanging with the family, and submitting a change to GPS for a warning message, I am back with an update. I wanted to show how this can automates a process.
Several evaluation and prototyping boards including the Teensy do not include connectors. Adding connectors require soldering...until the Viaconnect. If you are not sure you want to commit something to solder, the ViaConnect can allow you to test.
Say you get a ding and dent item from Sparkfun that just has 0.1" connector vias. How do you test this without soldering a connector? The ViaConnect automates the process of testing to see if the board is working much faster than adding connectors via soldering.
That is great timing! Let me know if you have questions or comments. Happy hacking!
Timing is everything. Earlier today I was holding bare wires in through-holes trying to get three of them to make contact at the same time - then I saw this log pop up. Great idea! I need to build a bunch of these ASAP...
