This project aims to get working setup of e980 LCD(LH550WF1-SD01 panel from LG) with ssd2828 Parallel LCD->MIPI bridge
an2.zipscreen shots of Application note for FHD display. If somebody got this document in pdf - send me link plz)Zip Archive - 822.13 kB - 04/20/2016 at 10:01 |
Adopted sample code from datasheet to stm32f3 deiscovery board, was able to read ID of the IC. Connectors arrived, schematic for adapter board almost ready!)
Got the board and now fabricating adapters for lcd->mipi board, and mipi board->beaglebone
Right now I've received LCD and looking for PCB connector. Still waiting for ssd2828 breakout. Next step will be manufacturing board to connect LCD to ssd2828 + backlight driver
I'm assuming this is dead in the water?
