Finally got a plasma cutter so I could work sheet metal and make the fume hood to work with the nasty chemicals required.
Plasma cutting is relatively easy, however, unless you have a very good worksop, it requires some way to contain the sparks it produces, so I had to build a water bath and cut support.
A secondhand metal box was bought:
And welded shut because the ends where just spot welded.
Painted it with anti rust paint:
The cut support was made to fit inside the box and have removable blades:
As first project, I made a monitor panel for the sputtering machine.
Good thing about plasma cutting, is that you can make wood templates, and so I lasercut some:
You must remember to adjust for the kerf and nozzle width (for my cutter it's 3.375mm/r (1mm kerf)
I have much to learn on plasma cutting, so this was not perfect, but should work.
Since this uses high voltage and I didn't want to have weird feedback loops between the instruments, I installed separate battery holders for each one. They are 9V flip-ups from guitar equipment.
Nixie
