Under the Hood. (part 1)
A project log for Semiconductors @ Home
Building all the tools neccesary to make chips at home.
nixieNixie • 07/14/2018 at 10:16•0 Comments
Finally, the fume hood is in the works!
I was unsure about what I wanted to do, so I sat in front of the computer and started to look into what the industry does.
I also found complete molded HDPE fume hoods, wich look fantastic, and not super expensive (300ish €)
But in the end, anything I could make was bound to be cheaper.
First I marked the avaliable space on the table.
70x30x30cm.
Once I clearly saw the boundaries, the design quickly came to my mind. It had to have a closed bottom so any small spills where contained, and be easily fabricated.
A simple C shape with 30mm height arm rest, and two side plates.
At first I thought I could half cut the sheet with an angle grinder and bend it by hand, but for 700mm width, that was not feasible, nor weldable with the experience I have.
After asking in a metal workshop, bending was so cheap, I opted to have it profesionally done instead.
Next time, finished hood!
