The recent Python code can be found in the Github repository. After the code v0.2, I cleaned out the code. I made a new mChimes.py file which is imported from all the other files. The main static settings are in this file as well. As a result all the other files became very short. Enjoy.
chimeClock.py:
import datetime, sys, zmq
import mChimes as chimes
speed = 0.8
firstQuarter = "1:%(speed)s-2:%(speed)s-3:%(speed)s-4:%(doubleSpeed)s" % {"speed": speed, "doubleSpeed": speed * 2}
secondQuarter = "3:%(speed)s-1:%(speed)s-2:%(speed)s-4:%(doubleSpeed)s-3:%(speed)s-2:%(speed)s-2:%(speed)s-3:%(doubleSpeed)s" % {"speed": speed, "doubleSpeed": speed * 2}
thirdQuarter = "1:%(speed)s-3:%(speed)s-2:%(speed)s-4:%(doubleSpeed)s-4:%(speed)s-2:%(speed)s-1:%(speed)s-3:%(doubleSpeed)s-1:%(speed)s-2:%(speed)s-3:%(speed)s-4:%(doubleSpeed)s" % {"speed": speed, "doubleSpeed": speed * 2}
fourthQuarter = "3:%(speed)s-1:%(speed)s-2:%(speed)s-4:%(doubleSpeed)s-3:%(speed)s-2:%(speed)s-1:%(speed)s-3:%(doubleSpeed)s-1:%(speed)s-3:%(speed)s-2:%(speed)s-4:%(doubleSpeed)s-4:%(speed)s-2:%(speed)s-1:%(speed)s-3:%(doubleSpeed)s" % {"speed": speed, "doubleSpeed": speed * 2}
Hour = "0:%(speed)s"% {"speed": speed * 4}
now=datetime.datetime.now()
if now.minute == 15:
chimes.sound(firstQuarter)
elif now.minute == 30:
chimes.sound(secondQuarter)
elif now.minute == 45:
chimes.sound(thirdQuarter)
elif now.minute == 0:
if(now.hour > 12):
hour = now.hour - 11
elif(now.hour == 0 ):
hour = 12
else:
hour = now.hour
chimes.sound(fourthQuarter+'-%s' % '-'.join(str(Hour) for x in xrange(1,hour)))
