... when speaking of extruder power. I'm taking a reallly close look at extruder design -- probably the single most power-hungry item on a plastic-filament 3D printer. I think we can miniaturize the design quite a lot ... using a Kapton heater in the 5-10 Watt range. Maybe using a high-frequency buck/boost converter to bump up the 7.2 VDC to 28 VDC or higher.
The current extruder designs are really clever, but clearly not based on minimum power use.
Any thoughts from anybody?
http://hackaday.com/2014/05/03/ask-hackaday-can-the-lix-3d-printing-pen-actually-work/
Make sure you have enough wattage for your desired extrusion rate, or you'll have to slow down your robots dramatically!
