As per the title, I've managed to get the initial PCB layout done. It isn't pretty, and I don't like the idea of making it by hand as I had intended, but it should work – barring faults in my schematic (of which there are probably at least a few), routing (possible, but I hope not!) or footprints (hopefully none). Ideally I'll add some copper pours, but I've got to be careful with that because of potentially high voltages in some areas – and on that note, I've got to adjust a few traces to ensure correct clearances around the two current-measurement terminals.
So here's some pertinent details about the design of the PCB:
- 2 layers
- 130 mm x 90 mm board
- Minimum track width and clearance are both 0.25 mm (0.984 mil) – the maximum possible for components with a 0.5 mm pitch.
- Via size is 1.8 mm with a drill size of 0.8 mm.
- It should be possible to make by hand at home – the biggest annoyance would be the 246 holes, of which 98 are through-hole components or headers, 141 are vias, and 7 are mounting holes.
