I made a list of components with pictures, references, link to the product and a ballpark price to make it easier to find the same components. Not all DVB-T dongles work well with the Raspberry Pi (driver wise), some look very similar, so one has to take care to look which components are used inside. The one I used works out of the box.
DVB-T references to terrestrial digital video broadcasting, this is kind of a hit-and-miss technique depending on where live you and where you can put the device. The signals might not propagate everywhere. If possible/available DVB-C (cable) should be preferred.
I needed to roll my own USB extension cable because of the enclosure size I chose, an easier way would be to simply attach the DVB-T dongle to the RPi and buy a bigger enclosure...
For the USB connectors I bought a male micro-USB to female USB-A connector and broke it to get the components, it was cheaper this way.
| Picture | Reference | Link | Price |
![]() | Raspberry Pi 3 model B Wi-Fi is needed to transmit data to the local router, possibly from outside the house | Link | $35 |
![]() | Micro SD card 8GB should be the minimum | Link | $10 |
![]() | DVB-T receiver with antenna With RTL2832U and R820T | Link | $8 |
![]() | Power supply 100V-230V to 5V/2A, the type doesn't matter as it's going to be broken and put inside of the project box | Link | $3 |
![]() | Male micro USB connector To connect power to the RPi3 | Link | $0.5 |
![]() | Female USB-A connector To connect the DVB-T receiver | Link | $0.5 |
![]() | Male USB-A connector To connect the DVB-T receiver to the RPi3 | Link | $1 |
![]() | Junction box A junction box is a nice project box as it has IP65 is protection norm (can be left outside) 100mm by 100mm is really the strict minimum, I can barely fit everything inside I bought mine from a local shop, so the exact same one might not be on eBay | Link | $5 |
![]() | AC power supply cable This depends on the region you live in | Link | $2 |
| 9 parts | Total | $65 |
Some soldering and wire are also needed for the assembly.
