I installed the printed gearbox in UMMD last night and ran the first test: lifting 4 kg at 10 mm/sec (the bed and support assembly weigh 3.5 kg):
First test of printed worm gear box in UMMD from Mark Rehorst on Vimeo.
Details:
1600 usteps/mm
100 full steps/mm
40:1 gear reduction
3 kg cm NEMA-17 stepper
40 tooth drive pulleys
2 mm pitch GT2 belt
More tests to come...
