The body is made out of machined 6061 aluminum with the same aluminum for the barrel and loading tube. The loading system will be a lever actuated (old school Winchester style) falling block breach. The lever forces the block up, allowing the spring fed loading tube to slide a cartridge into the block. Then the lever is pulled back into place causing the block to return to the firing position so the firing pin can be hit, launching the canister.
Here is the finished product!
Alex Anderson
Frank Herrmann
Robin Reiter
Greg Stephens
Cadmium
This project is really cool I love the pump action and the rising breach block, it really adds to the "hodge podge" aesthetic. One thing that disappointed me about the whole project was how inaccurate it is. I was wondering if it's possible to make it more accurate by adding rifling or making the gun a bullpup design allowing the barrel to be longer. In your experience with building the gun do you think these changes make difference?
