This is my initial Flow Chart for how I want the meter to function. I'm still working out a number of details:
- Contact selection for different strips
- Working on a list of strip pin-outs (really "contact-outs")
- Type of configuration for each type of strip
- I'll cover details of this in my next post.
- Pin selections for different strips
- Since strips have different contact orientations and different arrangements of electrodes used for glucose measurement (I will cover this in greater detail in a future post - here or on my blog)
- Some use 1 reference and 1 active
- Others use 1 reference, 1 active and 1 counter
- (there may be others, but I haven't seen them yet)
- This means some strips may need to utilize additional Op-Amps and ADC's to be able to read the strip
- Many strips also include additional sense electrodes to detect when blood first contacts the strip.
Continuing work on software development (at present this is my biggest challenge, this is my first attempt at using PIC microcontrollers - which require a lot of digging through details in datasheets - in comparison the hardware design is fairly easy) as well as deconstructing commercial strips to determine layouts of contacts and configuration of test strips.
