I received my parts order, including a PIkit3 (to program and debug the PIC microcontroller).
- Did forget a few capacitors, which I can get locally.
- Ordering a new LCD - since I dropped the current one.
- Using the regular 16F1786 (instead of the 16LF1786 - which seems to be unavailable anymore).
Downloaded and Installed MPLAB X IDE
Downloaded and Installed C-compiler for 8 bit PICS – XC8
As expected, had a few minor problems in setting up MPLAB X IDE but I got it figured out. Imported Reference Design Code into MPLAB X IDE. So far I've fixed a few errors that prevented the code from compiling - currently getting error that it doesn't recognize VREGCONbits.
Beginning a strip dissection to map it's pinout. I'll post up pictures as soon as I'm done.
OMG - I got it to compile with no errors. Time to start debugging and then editing and adding to code.
