Test Strip Profiles
A project log for Universal Glucometer
Did your test strips just get more expensive? Has the drug store run out of strips for YOUR meter? Like to be able to use any test strip?
tom-meehanTom Meehan • 09/16/2016 at 19:35•1 Comment
This is the start of building up a database on test strips. I'm starting with the pin-outs/contacts for the strips I know so far.
The plan is to have a list of strips, contact locations for working electrode, dimensions of the contact area of each strip (spacing between contacts and distance from base of the strip to the center of each contact), and then work to develop the best fit equations for glucose response for each strip.
ReliOn Ultima Test Strip
Freestyle Test Strip
Accucheck Aviva Plus Test Strip
One Touch Ultra Test Strip
The One Touch Ultra Blue looks to have a slightly different arrangement.
This is just a start!!!
mohamedaimenebenariba wrote 02/24/2018 at 09:43 • point
I'm very interesting about your project
