Due to code not working consistently - I'm re-writing and simplifying my code to meet my objectives and leaving other unnecessary functions out for now. I need to go back to basics and make the code simpler and more straightforward.
One main area, that I found, that made the code freeze up at times was the strip sensing method - which I have redesigned with an easy to implement hardware and coding solution that should work for all types of strips.
I'll post the essentials to later today.
